1 - 9 of 9 Posts
Wich fuel injectors should i go with i would like something better than the stock
Well not knowing what bolt ons you have so far and if you don't plan on going FI I believe 24 lb injectors should be good. I've heard that if you go higher that you need a bigger fuel pump and such but idk if that's true
Discussion Starter · #5 ·
Im switching the manifold cause the plastic of the back broke off where it connects to a hose so that part is not replaceable so i have to change the whole manifold by removing the fuel injectors do i have to change the o rings on them
The o rings are super cheap I would change them just because
1 - 9 of 9 Posts
