What kind of aluminum heads? That's pretty good numbers.Quball19 said:306,75 mm tb ,76mm maf, xcam, aluminum heads,24# injector, bbk ssi intake, long tube headers,255 fuel pump(42# preasure)
That's actually not too badQuball19 said:Well back from dyno tune ..it purrs,.. Numbers not what I was looking for.. 312 rwhp 368 torque,12.4 afr,4.9 maf. They didn't max tune yet because new rebuild, will get about 10+ more wants broke in and take it back . Thanks alot for all help you all give me.
My set up is very similar. Differences are a 70MM TB, Edelbrock RPM heads port matched, ported Cobra intake, shorty equal length headers and a 190 lph pump.306,75 mm tb ,76mm maf, xcam, aluminum heads,24# injector, bbk ssi intake, long tube headers,255 fuel pump(42# preasure)
Do you have any pictures of what it look like after the rails were welded, I have the same intake mine is sparaticly leaking so I want to solve the issue now while I have it apart.So, basically I am turning my old ones to new ones. Mine are welded up getting ready to repaint them and hook back up with my 90 degree lines. Thank you
