1 - 19 of 19 Posts
Discussion Starter #1
Is 32 psi to low I been having issues lack of power misses terribly on start up idles fine after about 5 mins of runtime but no power. If it sits for maybe 2hrs or so when I start it back up it runs like crap again for about 5 mins. I have pretty much checked and tested every sensor that I am aware of other than the act sensor, i set timing ect only thing I can figure out is maybe fuel pressure??? Or blown head gasket between cylinders thought I had done a pretty thorough compression check but maybe not lol. O and it always seems to be running rich and about have throttle there is a dead spot in power
---------- Post added at 09:55 PM ---------- Previous post was at 09:53 PM ----------
Any input is appreciated this thing is getting on my last nerve lol... And it is completely stock
Re: Fuel pressure
What about a leaking injector..When the pressure comes up on the gauge during a key on engine off,,does it slowly drop off,,that could indicate a stuck open injector,,Also check the fuel filter,,if the pressures low
Discussion Starter #4
Yea im kinda thinking injector cuz it has always seemed to run really rich
---------- Post added at 08:37 AM ---------- Previous post was at 08:33 AM ----------
Thats what i thought 38-40 with it unplugged I guess that would be the reason for it backfiring on startup as well.
Banned
Re: Fuel pressure
Your fuel pressure should be 38-40 with the engine idling and the vacuum hose on the regulator removed and plugged off. When you reconnect the vacuum hose the fuel pressure will drop some.
You should also check your timing. Don't forget to remove the spout plug before checking/setting and to replace it afterwards.
If you do not have a Chiltons manual for your car, get one. They contain a lot of specs and procedures for testing and working on your car.
Banned
I prefer Chilton over Haynes. But with that said I only have a Haynes. If your gonna fork up money for another book I would recommend getting the ford service manual. It can be had for around 30$ and will blow both books put together out of the water.:good:
Discussion Starter #9
the fuel pressure is supposed to rise as u rev the engine right? it just seems like it floods itself out at higher rpm especially if the throttle is wide open
Discussion Starter #10
I believe I may have a faulty fuel injector how long should the fuel system hold pressure I put a gauge on it had 32 when I left came back in 4hrs and it was 0 would this be normal or could I possibly have a leaking injector
That could indicate a leaky injector or regulator either one. Run some tech rpm through it and see if it helps. If it affects it at all it is the injectors. How hard to start is it?
Discussion Starter #12
Easy to start but it runs rough for like 2mins then clears but doesn't have power that it should and at wot its like it has a rev limiter
---------- Post added at 10:23 PM ---------- Previous post was at 10:22 PM ----------
But if it sits for a while it runs rough again... And smells really rich
1 - 19 of 19 Posts
