1 - 14 of 14 Posts
Discussion Starter #1
Thought fuel pump went out because i could not hear it prime so I checked the relay under the hood and it was good. I jumped the inertia switch in the trunk and it did nothing. I finally changed the pump and it still did not work. What am I missing? Any help would be appreciated.
Discussion Starter #3
93slowstang said:
It could be your ignition switch or possibly a fuse.
The ccrm is clicking when I turn the key to try and prime the FP. Could a relay click even if its gone bad?
i am having the same problem with my 94 gt, i put a brand new FP in, in June. I unpluges the wiring going to the puimp, so i am getting power to it. I checked all the relays, they are all good. Have to check if the connection to the fuel pump is bad, or if my pump just seized up.
Banned
If it clicks once then stops, it is probably ok, but if it continues to click multiple times then the relay coil is failing and won't hold it on.
If your fuel line is already fully pressurized, you may not hear the pump run when the key is turned on. Does the car start and run at all?
Discussion Starter #7
Will not hit a lick. Checked to see if I had fuel pressure at my regulator and nothing came out. In the ccrm there are several relays so could it be one of the others clicking?
Banned
Possibly, yes. Look in the Useful Info thread and in the Very Useful or Old Fuel Injection links you should be able to find a CCRM diagram that will help you identify the relays. It's handy to have for troubleshooting. :good:
Have you checked to see if you have power to the pump?
Discussion Starter #9
No power to the fuel pump or the inertia switch. I did switch the ccrm out with a buddies good one but didn't solve my problem. Have 12v going to the 20A fuse in the engine compartment. Not real sure how to test if I have power coming out of the ccrm.
Banned
Use a diagram to figure out which relay it is in the CCRM and which wires you need to test. :good:
Discussion Starter #11
I connected the right port of my data link connector(Behind passenger shock tower) to ground which should've made my pump run continually but it didn't. What does this mean?
Discussion Starter #12
Fuel pump relay diagnostics:
First, always check the inertia switch in the trunk and the fuel pump fuse in the underhood fuse box (20 amps). Also check the ignition switch fuses. With the key turned to run and checking within the fuel pump prime-out period (a duration of 2-5 seconds after turning the key to run): Check CCRM pin 5 for accessory 12 volts. If you have it, the issue lies downstream. If not: Check CCRM Pin 11 for constant 12 volts. Check CCRM Pin 13 for accessory 12 volts. Check CCRM Pin 18 for a ground signal during the prime-out.
If this is all good, check the inertia switch (located in the driver side trunk, adjacent the tail light) and fuel pump electrical connector at the tank.
If I'm not getting 12v on pin 5 does that mean the problem is upstream? God, I hate electrical problems!
Discussion Starter #13
Just a follow up, I've located the problem. I was cleaning out the glovebox and apparently previous owner installed a FP shutoff switch in there. I hit the switch and never knew it. I had the whole car torn apart but traced it all the way to the switch. Thanks for your help.
Banned
:eek: It would have been nice if he had told you that.
Anyways, glad you found your new "theft" protection switch and solved your problem. :good:
1 - 14 of 14 Posts
