1 - 4 of 4 Posts
Discussion Starter #1
New here from Pennsylvania - I just aquired a 71 Mach 1 and noticed an electric fuel pump wired up in the trunk on the left side behind the wheel well. There is a toggle switch wired up to the center console. Is the electrical fuel pump the way to go or would the mechanical style fuel pump be good enough for a 800cfm 4 barrel carb?
I think mech would work, but you're adding a little more drag to the motor. Plus you lose the kill switch in the console. Does it not work right?
Discussion Starter #3
Not sure if it's working properly yet, had some carb issues..overhauling as we speak. Would I need a fuel pressure regulator for the electric pump with a carb set up?
You will have to have a pressure regulator to get it down low enough for a carb. One other thing you'll need a fuel shut off in case of a wreck, otherwise it keeps pumping tll the battery dies.
1 - 4 of 4 Posts
