1 - 5 of 5 Posts
Discussion Starter #4
Thanks guys, I've had my rear differential cover replaced by the dealer though so I would expect that marking is long gone, I'll have to check next time I'm under there.
Easy way to check what gear ratio came in your car from factory is to open the drivers door and look at the data tag bottom of the tag in the middle under the word axle will be a code
CG=3.31
CD=3.55
CB=3.73
These are the codes for limited slip rears
Heres the link wear I found these codes ford gear ratios
1 - 5 of 5 Posts
