Which should i do first?
no you will need the tuner if you go with gears. its really up to u man. if the stock 4x4 stance doesnt bother u too much just buy the gear tuner comboI cant decide. If i did gears w/o tuner i could do both.
Dont need. I have a 5 speed. Ittl just throwno you will need the tuner if you go with gears. its really up to u man. if the stock 4x4 stance doesnt bother u too much just buy the gear tuner combo
oh ok well if ur cool with it just go for the springs and the gearsDont need. I have a 5 speed. Ittl just throw
My speedo off. I can live with th that.
It will also throw off your tachometer... But if you know when to shift and can interpret the readings of the speedo to what you are actually going then you should be good without a tuner.Dont need. I have a 5 speed. Ittl just throw
I never watch rpms anyways. Can usually tell when to shift by feel/sound.It will also throw off your tachometer... But if you know when to shift and can interpret the readings of the speedo to what you are actually going then you should be good without a tuner.
