1 - 15 of 15 Posts
Discussion Starter · #1 · (Edited)
Ok, as i was reading another post i thought about something.. My car has 3.73's now. So does that mean that my speedo cal. is off? I am actually running faster than what it says???
These were from the other post...
Brent said:
It will throw the speedo off.
If you get a chip it will correct the speedo and it will remove your speed limiter which will be lowered by the new gears.
Danger Dude said:
Yes it will you can get a SCT chip to correct it and at the same time get the Rev limiter raised and the speed limiter removed and it will get you extra HP and Torque
did the previous owner have a speeecal put on or had he ever put on a chip? what is your top speed at the moment?
Discussion Starter · #3 ·
Dont know actually i will call him now and ask... and i dont know my top speed right now, really havent pushed my car that hard. trying not to break it. :lol:
Banned
is it a 5 speed or auto? If its a auto and you dont have a chip to clean up the shift points your shifting will be very sloppy
Usually people put their speedcal here: this is where I have mine... probably wont work if you got a 5-speed though not sure
Discussion Starter · #5 ·
Ok, he says that when shane "SR" (im sure you all know who that is..) put the gears in he put the speedo gear in the tranny.... and said it may be a little off but only by 1 or 2 mph? would it be slower or faster than the reading if off???
Discussion Starter · #6 ·
yes it is a 5-speed.
Banned
You should be close to accurate with a speedo for 3.73's 4.10's on the other hand will throw you off 10mph easily with a speedo gear.
I would think you would be close to accurate with that speedo gear. Cant say for sure but I am pretty certain your only 1-2mph off
232stang said:
it would read faster than it was actually going
They do that straight from the factory
a speedo gear = WAY off.... you are probably looking at 6mph to fast.... get a friend to go the speed limit and you go beside him and see.
when i had my 97 i put a speedo gear in it and with 3.73s i was 6-7 mph to fast.
You can put a speedcal unit it (probably will work for your year just check) and it will correct it 100% just have to pop the old speedo gear back in (stock spec)
Banned
He doesnt have to put the old spedo gear back in, just make sure he uses that speedo gear he currently has when he is configuring the speedcal.
6-7 mph? hmmm
true they should have a speedo gear selection on there else its a 10 buck part... and even better you can run just about ANY size wheel/tire you want on the bakc and just recalibrate it in like 5 min....
Discussion Starter · #13 ·
So when my speedo says im doin 50 im really doin 55-56? or im doin 45 or 44?? :thanks:
Pull out a GPS and find out..that's how I did my old car. If you don't have one of those just get a friend to drive beside you at the speed limit and see what yours reads.
well who knows what speedogear they used... just get a friend to go the speedlimit at 45,55,65,35 all of those adn you can see where you are...
an odd getto trick I tried on my 97 since I had no clue of a speedcal at the time was i pulled the clear gauge cover and poped off the speedo needle. got a friend to go 55mph and I stuck it on at 55mph.... it was accurate from 35+ (well i never went past 70~ or so since i cut off at 85 anyway) its just an odd little getto mod.
1 - 15 of 15 Posts
