Should of kept the mark VIII, I was running 14.0 flats with just a high stall in my 94 mark, then I installed 410 gears but never made it back to the track but I'm assuming it would of of run mid 13s, plus I still had plenty of mods I could of doneJheard517 said:I've only had it to the track once, I picked it up about 4 months ago. I got it from an older lady with 62,000 miles on it. It came with a JLT CAI, and SLP OR/ x pipe with deleted cats. So till stock, with **** tires I ran a mid 14. I just to see low 13s hight 12s. I'm new to the mustang but I had a 97 mark 8 LSC that I did work to. But it's def a different car.
You honestly can't go wrong. It really depends on what your goals are for the car. Basically if its your daily driver and you go on the highway often, then I'd go with 3.73's.Anyone regret getting 4.10 gears instead if 3.73s? Or regret getting 3.73s instead if 4.10s. If so why? I have a 2000 gt vert 5 speed. Let me know thanks
So everything you're saying here definitely steers you in the direction of 4.10's! However if you do plan on going SC, 4.10s may be a lot of gear. You'll be shifting every time you hit full boost, but it will be on wicked weekend car.It's not my everyday car, I mainly take it out on the weekends to cruise and go head hunting. I'm not worried about gas mileage, cause I just don't care lol. The only thing I'm worried about is traction issues, if someone can let me know of a good street/drag radial I'm sure ill be ok. I want to build up the car as much as I can. I do want to put on a s/c but you know how things change down the road. I just want to be happy even if I change my mind about the sc.
