You made a catch can? Can u show pics and possible items used to make it?
You made a catch can? Can u show pics and possible items used to make it?There is a PCV valve in the head cover; as member ronnie has pointed out, the large 3 manufacturers got a PCV valve "certified" to use as a crankcase ventilation system a long time ago. It allows the gases from ring blowby to venilate through this valve, and back into the intake to be reburned. It also allows oil mist, which over time, can get onto the backsides of the valves, causing poor performance. I never thought much about this until I made a catch can. I now empty about a teaspoon of oil out of it every 3 to 4 weeks.
PCV Looks like this:
Here's a picture of it on a thread I started a few months back:You made a catch can? Can u show pics and possible items used to make it?
The maf adaptor comes with a plastic tube for the inside use one of them if that doesnt work flip adaptor other way so maf facing the other way.The throttle is super laggy, idle is really rough and it smells a little like oil/gas now... Help guys , got people waiting for me somewhere lmao I'm so screwed
But try the plastic tubes every way possible before flipping adaptorThe throttle is super laggy, idle is really rough and it smells a little like oil/gas now... Help guys , got people waiting for me somewhere lmao I'm so screwed
The maf adaptor needs thatI just finished my intake and the car is idling, and eventually stalling.
Its 4" MAF adapter to 3" piping...is the filter too large????
Everything is hooked up and sealed.
The maf adaptor needs that black piece that slides in with a section cut out for the MAF sensor. Add that to the adaptor and it will work fine.I just finished my intake and the car is idling, and eventually stalling.
Beat you already;b hahaThe maf adaptor needs that
---------- Post added at 10:46 AM ---------- Previous post was at 10:45 AM ----------
Darn u!!!Beat you already;b haha
So now instead of actual cold air coming into the stock filter you have a filter sitting above the header pipe?I removed the vacuum line and put a filter on it. That let me get rid of that last section of tube.... I like it more now, just looks cleaner
Its not a good setup unless u run breather filters on both valves. Otherwise u create a suction and ur letting unmetered air into ur crankcaseSo now instead of actual cold air coming into the stock filter you have a filter sitting above the header pipe?
Interesting
You can run a breather on the pcv, its fine, you need a breather on the other side of the intake manifold as well. I chose to keep my pcv just to try to keep the car as stock as possible. There's no benefits to breather filters, just losing your unburned gasesI don't think you would want to run a breather on the PCV. It's going to clog with oil.
Or do you mean something else by "both valves"
