1 - 10 of 10 Posts
Discussion Starter · #1 ·
i've looked into several ideas for an audio setup and for now i just want 1 sub, but be able to put in a second with re-wiring a new amp. so if i were to install this:
12" Rockford Fosgate Punch 2
@ 50-200w RMS & 400w peak
What amp should i get for this so i don't have to buy another when i get a second sub?
also, i have the stock head unit with single cd player. do i need an aftermarket one to wire it all in?
Banned
Dont get single voice coil
Get Dual 2ohm subs for best wiring options
That way you can buy a amp at 200x1 @ 4ohms and 400x1 @ 2ohms and power that one sub then when you add another sub you can wire it to 2ohm
Understand what I am saying?
Discussion Starter · #6 ·
ah ok. i'll look into that. next question:
when i re-wire for 2 subs, do i rewire at the amp only or do i have to go back through the car and etc?
you will have only one set of RCA's comming back wiht a power wire and what not, the amp will have to be altered for mroe than one sub but thats all you will have to alter.
Discussion Starter · #8 ·
this is a mono-amp right? is there an advantage to getting a 2 or multichannel?
1 - 10 of 10 Posts
