1 - 15 of 15 Posts
Discussion Starter · #1 ·
Okay so I have these halo fog grill lights and when I took it off I noticed there is in fact two bulbs inside the fogs. Is there anyway to get those light to shine!
The previous owner put in this aftermarket grill and I can see he got them from eBay.
Thanks in advance!
I have halo fog lights they light up
What bulbs are you talking about lighting then
---------- Post added at 11:25 PM ---------- Previous post was at 11:23 PM ----------
The halos are just halos. The bulbs inside the glass/plastic fog lights are the actual fog lights
You'll need a fog light harness to hook them up then. Or go to a parts store and get the right socket for that bulb and just fab something up. That's all I'd do hell. It looks like a 9006 bulb possibly
Discussion Starter · #8 ·
Couldn't I wire them to the headlights?
And 9006?
And 9006?
I suppose you could. It has the stock lights right? You'd have to wire them to the low or the high beam though. Those fogs are single beam whereas if your headlights are stock are dual beam
---------- Post added at 11:33 PM ---------- Previous post was at 11:32 PM ----------
9006 is the bulb part # for that fog light bulb possibly. If headlights stock they should be a 9008(h13) just part #s
Discussion Starter · #10 ·
I should wire to low beams:)
And 9006 is what color?
I would recommend low beam like you said
Ha 9006 is the part #! Not the kelvin (burn temperature)
1 - 15 of 15 Posts
