1 - 3 of 3 Posts
Discussion Starter #1
Edelbrock victor jr, afr 185, or trick flow 190 fac? I've got a spider victor jr with elbow Anderson n-91 cam 75 mm tb 76 mm maf 24 lb injectors. Jut seeing what I get for head opinions. Thanks everybody
Banned
Unless you supercharge your engine, build a large cubic inch engine or build it for high RPM's, you won't see much benefits from using that intake and it is likely to kill your bottom end.
It is most usually used with heads like the AFR 205 or 225's.
What exactly do you wish to accomplish with your car?
What heads are on the car now? What are the plans for the car?
1 - 3 of 3 Posts
