1 - 4 of 4 Posts
Discussion Starter #1
Hey guys the silicone that protects my lights from leaks and stuff has come off...where can I buy new silicone or whatever it is?
go get a tube of black RTV from any autoparts and seal it away...i'd do it before you do get moisture in there and cause it to yellow on the inside
Discussion Starter #3
There's already moisture in there :(((((
then before you seal them i'd get out as much as you can...try taking them off and setting them inside for a night or so to dry. i've also thought about taking those moisture packs that shoes and such get shipped with and putting some on a string..then dropping it down the headlight hole to leave overnight and see if that'll pull in moisture.
1 - 4 of 4 Posts
