What setup do you have now? I'll try to get a good pic of mine tonight when it starts to get darkshould they match eachother?
i have 8k on headlights and foglights both 35w they dont match the fogs are bluer. if i get the 6k for both and they are both 35w i want to know if they will match. i hope they will.What setup do you have now? I'll try to get a good pic of mine tonight when it starts to get dark
No problem, man...I was thinking of smoked fogs too, but then I would have the different color HID problem too so I just decided to go with the traditional amber color for my fogs.@AirAndAsphalt and @dmarq. Thank you for answering my question about the difference between 35W&55W, and also for your input and telling me about those websites, ill be sure to check them out when it comes time to get my HIDs. And @mustang17, I'm worried about the same thing happening to me. The lights don't match now and with my aftermarket smoked fog lights I installed and I don't want to upgrade to HIDs just yet until I figure out what is gonna match or come closest to matching.
Hmm probably not. The higher color temp is just going to be bluer, not brighter. 5000k is the brightest hid bulbs you can possibly get, it's the purest light. You should probably just get same color, honestly. It should be the same color. Although I've never had smoked lights so I'm not the most experienced with them. Btw a lot of people use 55w for headlights bc they are brighter. But bc it's brighter it tends to wash out the color a little.So if I were to get 35W 6000k for my headlights, should I get 8000k for my fog lights since they are smoked?
Yeah, I guess if its bright enough, it wouldn't be too noticeable. As long as its not an obvious difference in color ill be happy. I also have two lights towards the bottom (my highbeams) which I've never seen anybody have so far, so I'm gonna have to figure out how to get the HIDs down there too.Hmm probably not. The higher color temp is just going to be bluer, not brighter. 5000k is the brightest hid bulbs you can possibly get, it's the purest light. You should probably just get same color, honestly. It should be the same color. Although I've never had smoked lights so I'm not the most experienced with them. Btw a lot of people use 55w for headlights bc they are brighter. But bc it's brighter it tends to wash out the color a little.
Yeah, I was looking at your pics, I've not seen HID bulbs for those smaller unit....Yeah, I guess if its bright enough, it wouldn't be too noticeable. As long as its not an obvious difference in color ill be happy. I also have two lights towards the bottom (my highbeams) which I've never seen anybody have so far, so I'm gonna have to figure out how to get the HIDs down there too.
All you really need to know is what type of bulbs it uses and where to mount the ballasts and you're goodYeah, I guess if its bright enough, it wouldn't be too noticeable. As long as its not an obvious difference in color ill be happy. I also have two lights towards the bottom (my highbeams) which I've never seen anybody have so far, so I'm gonna have to figure out how to get the HIDs down there too.
So I would just have to look in the owners manual for that?All you really need to know is what type of bulbs it uses and where to mount the ballasts and you're good
And those gave off that clear white light or still that yellowish haze ?ordered my old HID kit off the vvme website. Their shipping is fast and their customer service is excellent. 12v 55w digital slim h13 9008 bi xenon HID kit with 6000k bulbs is what I will be ordering next for my mustang..it's around $50-60....i need to stop dragging my feet. The install is easy as hell, just plug some wiring harnesses into your existing wiring and that is pretty much it. Just be sure to find a good spot to ground it to and that will eliminate most of your problems.
Can search all types of bulbs here...So I would just have to look in the owners manual for that?
I don't believe those high beams are stock, so you'd need to find out what bulbs they are a different waySo I would just have to look in the owners manual for that?
Actually, if the kit is designed for the specific bulb type, as most kits today are, they will just plug into the socket for the old bulb, which already contains a grounding wire. So there's literally no extra wiring that needs to be done besides plugging in the kit and then mounting the ballasts. We have it good nowadaysCan search all types of bulbs here...
Headlight Bulb Headlights | Car Parts
And the ballasts you will just mount securely wherever you have a flat surface to screw them in. You will also need a bare spot of metal to attach your grounding wire.
As long as you have an HID setup, yes, you just put the correct color bulb in there that you want for your headlight plug. The bulbs aren't too different looking than normal ones. If you do not have an HID setup, then the HID bulb will still fit, but it won't have the power behind it and won't work the same...was that what you were asking?So if just get the correct bulb size, and replace it with the bulb I have now, that's all I have to do? Seems to easy to be true lol
