1 - 6 of 6 Posts
Discussion Starter #1
There has been two times that I have tried to start my car but all that happens is the electronics come on....no turnover or anything. Then just a few tries later it starts up just fine.....any idea what this could be?
Discussion Starter #3
Clutch was pushed down all the way...I am waiting for it to happen again before I take it in but I just wanted to see if anyone had ever had this issue...
Sounds like it might be seething in the tumbler of your ignition which would require the dealer. Do you just keep cycling it until it turns over?
Discussion Starter #5
Yes I cycle about 2 or 3 times and it turns over. It has only happened twice.
I would take it to them especially of it isn't consistent. You don't know when it will happen again and everything down stream of the the system itself will have an obvious sound to it.
1 - 6 of 6 Posts
