1 - 11 of 11 Posts
Discussion Starter · #1 ·
I was supposed to have my car in for an alignment this morning at 10 am, here I sit at almost noon, the thing won't run, stupid PATS thinks I am trying to steal my car I guess. It starts, then shuts down, seems to be shutting the fuel system down! What can I do here, HELP!! Any one know? :oops:
Discussion Starter · #4 ·
I have 2 keys, don't think the other will work either, but will try it again. Called ford, to reprogram PATs is 70 dollars, that is if it didnt' burn out some kinda module, ouch. :(
its not PATS. if it were PATS, the ECU wouldnt even send a signal to the starter and let it start.
go in the trunk, see if the fuel cutoff switch has been turned off accidently. thats what it sounds like. sounds like the engine isnt getting the fuel, and is just getting enough from whats in the fuel lines, then shutting off.
Discussion Starter · #7 ·
Was getting fuel, it flooded. The dash lights were working fine. It finally decided to start and run. Got my front end aligned at a different shop, got someone's appointment that didnt' show up. Still not sure what caused all that mess this AM, it took me til about 1PM to get it to start, I had to recharge my battery. :oops:
Discussion Starter · #8 ·
Oh, and I had already checked that switch in the trunk, it was not kicked.
Discussion Starter · #10 ·
I found out what the problem was. My chip had a factory defect, it didn't show up until the weather started to get a little cool. Reinhart is making me a new one, I sent him the original one Saturday. With the chip out it starts on cool mornings and runs fine. :headbang:
1 - 11 of 11 Posts
