1 - 6 of 6 Posts
Discussion Starter · #1 ·
Il try this again.. I have a 97 cobra with o/r x pipe, no cats with mil eliminators.. Im getting a p0174 lean code bank 2.. ive replaced all intake gaskets, MAF sensor, both o2 sensors on bank 2, coolant temp sensor. And i dont have a vacuum leak.. The only other thing i can think of is a bad Mil eliminator and i have a new set ordered.. Any other suggestions if this is not the solution??
You could try the spark plug fouler trick. I think that's what its called. Also those mil Eliminators are known for being iffy.
---------- Post added at 10:16 PM ---------- Previous post was at 10:14 PM ----------
A tune will get rid of it, if its from no cats.
1 - 6 of 6 Posts
