1 - 16 of 16 Posts
Discussion Starter #1 (Edited)
Okay so I got my car back from the body shop 2 weeks ago for a bent rear axel and when I start to slow down the brakes start pushing back at my foot after 10 mph , I took it back to the shop and they told me to take it to Firestone cause that where they took it to get aligned so I took it to Firestone and they told me that I have hot spots on my rotors and that I need new rotors and pads so I ordered them and i just got done installing them and its still doing it , I've bled the front but not the back yet , I'm starting to wonder iF its my ABS cause there's a clicking noise also . If any one has any idea whats going on plz let me know thanks !
TXstang125 said:
Okay so I got my car back from the body shop 2 weeks ago for a bent rear axel and when I start to slow down the brakes start pushing back at my foot after 10 mph , I took it back to the shop and they told me to take it to Firestone cause that where they took it to get aligned so I took it to Firestone and they told me that I have hot spots on my rotors and that I need new rotors and pads so I ordered them and i just got done installing them and its still doing it , I've bled the front but not the back yet , I'm starting to wounder it its my abs becauselike clicking noises also
Anytime you bleed your brakes always start at the master cylinder, then the farthest wheel (rear passenger), move on to the next (rear driver), then next (front passenger), then the last one!..
Could also be your ABS is acting up!..
I'm not certain of this, but it sounds like to me it could be a hub assembly. Is there anywhere else you can go to get a 2nd opinion?
---------- Post added at 09:32 PM ---------- Previous post was at 09:32 PM ----------
+1
Discussion Starter #4
This is a dumb question but where's the master cylinder ?? And how can I find out if its my ABS for sure
---------- Post added at 09:40 PM ---------- Previous post was at 09:37 PM ----------
Ummmm I really don't know where to go
Only dumb question is the one not asked!.. You know were your brake fluid reservoir is?... Right below it (its actually mounted to the top of) is the master cylinder!..
Discussion Starter #6 (Edited)
This right ? If so do u bleed them just like u do the ones on the calipers ?
TXstang125 said:
This right ? If so do u bleed them just like u do the ones on the wheel
Yes and yes!.. But make sure you've got plenty of fluid on hand and don't let that little tank get low!..
Just a quick thought here!.. Do you have any warning lights kicking on?.. Is your ABS light kicking on when this is happening?..
At any rate two things I would do if I were you!.. 1. Have a code scanner ran on your car!.. 2. Get a Haynes Repair Manual!.. It will walk you step by step how to repair and replace just about anything on your car!.. But still don't hesitate to ask any and all questions on here!..
Discussion Starter #8
Okay thanks man really appreciate it and no there's no ABS lights on
Then odds are its nothing to do with your ABS!.. But I personally would still run a scanner on it!..
Discussion Starter #10
Okay we'll ill probably go get it scanned this weekend if it still happens after I bleed the brakes Thanks for the help !
No problem dude!.. Let us know how it goes for ya!..
TXstang125 said:
Do u know what size the back bleeder is ? Ik the front is a 9mm and the master cylinder is a 10 mm
If your talking about the bleeders on the calipers themselves, then they are all the same!..
Discussion Starter #14
Okay so I bled everything and its still doing it not as bad as it was but it didn't go away , I'm taking it back to Firestone in the morning to get the ABS looked at
Are you sure you got all the air out?.. And ya I would take it in to get the ABS checked out then too!..
Discussion Starter #16
Finally got my braking problem fix ! my speed sensor was knocked out of place :| stupid Firestone made me buy new rotors and brake pads for nothing im never going back to that place
1 - 16 of 16 Posts
