I think we're talking about the same thing. There's a constant power wire (keeps everything you've saved on memory) and an ignition/switched 12 volt wire that only recieves power when the head unit is on. That's the wire I described for him to use and tap into. I tapped into the same exact wire on mine and it works perfectly fine.232stang said:just tap into the ignition wire behind the head unit, it would be a good remote![]()
Just get a sub/bass knob so u can turn it up and downi know it would be easier to wire the remote wire, but the reason i was thinking about a switch was in case i ever wanted to jam without my subs on. just a thought
