Help with engine problems suggestions
401 Views 4 Replies 4 Participants Last post by  5LHO
2
Hey everyone, I have a 2005 4.0l 1 of 1 mustang, it is a one of one because it is the first and only 4.0l 6spd/Auto with a Vortech Supercharger. I currently have issues as such; cracked valve covers at the bolt holes and I got ripped off but “liquid gaskets” when I needed new valve cover gaskets, this is the second engine. Only because the original owner took it to jiffy lube for a oil change and they hand tightened the oil pan nut and it popped out while driving and seized the engine, I believe they dropped this engine in without a tune so my A/F is completely wrong bouncing from 7.5 to max of - - I also replaced the intake filter which helped the A/F ratio a little bit to where now it doesn’t top out in an idle but a very rough idle. It’ll stall when you shift to a “moving” gear such as R,D,1,2,3. I currently haven’t started in months but I have it connected to a long term battery charger so it won’t die completely. I need peoples opinions what I should do, I get $965/month cause I’m on disability, I thought repairing everything and get a tune, my best quote in the state of Washington was $1200 for the valve covers and gaskets and $2000 for a full custom tune because “they didn’t know how bad the tune was and what they had to do”. Now, that’s not in my budget so I thought why not engine swap. I was looking for another 4.0 but not much room for improvement, so I then thought if I upgrade I can’t do a V8 otherwise it’ll lose the 1 of 1 plague, so I’d have to do a V6 or V10 but doing research on a mustang with a 6.7 f250 engine and everyone said it would ruin the ride because of the weight. I’m personally out of ideas so I’m leaving this with you for y’all’s help and opinions, pls/ty guys ✌🏻 Also here’s a couple photos for y’all too..
Wheel Tire Car Vehicle Window
Car Vehicle Hood Automotive lighting Motor vehicle
See less See more
1 - 5 of 5 Posts
Welcome and thank you for joining MustangEvolution!
Please read the Site Rules if you haven’t already.
I encourage you to complete your Account Settings.
If you need help posting? Please read this FAQ.
We’re happy you’ve chosen to join our community.
Someone will be along shortly to offer advice.
It sounds like your engine's been butchered and there are too many problems that need fixing. I suggest you find another decent running 4.0L V6 engine, replace the timing chains/tensioners/guides (especially the passenger side which are at the rear), and drop it in.
  • Like
Reactions: 2
And you couldn’t guess honestly how many miles are on this engine tho that’s why I’m soooo hesitant tho.. also nice bright red, I typically don’t like red but there are a couple red I do like and that red is one of them
The tune from the previous engine should have just worked (at least somewhat) with the new one. The ECM holds the tune, not the engine. I presume it ran well enough originally before all this stupid stuff started happening. It sounds like there has been more than just mechanical hackery here if it runs as bad as you say. I concur on just finding a decent 4.0 and putting that in. You are really getting in deep with custom everything to put a V10 in there, for example.
  • Like
Reactions: 1
1 - 5 of 5 Posts
