Has anybody with these white face gauges had any problems with them shorting out ??? I can't seem to fix it
Yea man I love them the only problem I'm having is them shorting out , witch just started and I need them to light up hahaBarrett775 said:I don't have those but they look awesome in the dark. I want some.
I'd call the manufacturer and complain.TXstang125 said:Yea man I love them the only problem I'm having is them shorting out , witch just started and I need them to light up haha
Yea I don't think there open.... LolBarrett775 said:I'd call the manufacturer and complain.
My assumption would be that they have a connection or a wire that is falling apart. I know on mine if one of the wires that sticks out below the cluster isn't just right one of the sections won't light. You should also check the ground wire.TXstang125 said:Has anybody with these white face gauges had any problems with them shorting out ??? I can't seem to fix it
+1 on the connections.My assumption would be that they have a connection or a wire that is falling apart. I know on mine if one of the wires that sticks out below the cluster isn't just right one of the sections won't light. You should also check the ground wire.
I snapped off the dimmer that came with the gauges and now I'm going to T-tap the wire into the dimmer on the car and ill see if that works9tee7pony said:My assumption would be that they have a connection or a wire that is falling apart. I know on mine if one of the wires that sticks out below the cluster isn't just right one of the sections won't light. You should also check the ground wire.
I got it I just had to get a new T-tap thanks for the help everyoneMatticus said:Did you create a new ground or try to use a ground already available? When I put mine in we had to drill a hole in the chassis to make a good ground. Have had no issues thus far.
There for sale atI don't have those but they look awesome in the dark. I want some.
