1 - 5 of 5 Posts
Discussion Starter · #1 ·
Ok so today I installed my SR upper intake plenum. In the process of doing this, the red vacuum lines broke at the top where it goes into the plenum. The car will start up, then shut right back off, is this the reasoning?
Also, they didn't give me the piece that goes in the plenum and allows the rubber piece connected to the vacuum lines to go over it. What's this called? I'm going to the dealership tomorrow to get all of this, but just wanna make sure it's my issue and all.
Discussion Starter · #3 ·
I'm not sure about the rubber piece but yes if those red lines aren't connected your car won't run.
Here's some pictures.
So you see the hole where it goes into the plenum? I'm supposed to have a piece to go into that, so that the vacuum line can go over it. (The piece on top of then plenum is what's supposed to slide over the piece they didn't give me)
Try and give am a call tomorrow they should be able to hook you up.
1 - 5 of 5 Posts
