1 - 5 of 5 Posts
You could try and connect the bulb that has less lighting to the other ballast on the other side. If there is still reduced lighting maybe its your bulb if the bulb shines brighter it could be the ballast.
---------- Post added at 04:01 PM ---------- Previous post was at 03:59 PM ----------
You can also replace just the ballast from the seller you bought them from or contacting them that you only want a ballast for the same HID kit you obtained.
Discussion Starter · #5 ·
gotcha thanks bro !
1 - 5 of 5 Posts
