1 - 20 of 32 Posts
Discussion Starter #1
Hey guys this is my first post here. I bought this 2012 V6 mustang at auction for super cheap because it wasn't running. I took it to ford and they told me it must have been hit by lightning or something crazy like that. They want to replace every single module in the car at a total of $10,000! My question is can I bypass some systems and just replace some of the modules to get it to run.
Damn. The new cars are just SO electronic.. Electric issues are something you should usually just leave to the dealer.. Is it not worth it to fix it? Idk what you payed for it.
It's not me, it's you.
Damn, sounds more like it went through an EMP field! That sucks! I'd put it back up on the auction block. You might turn a profit.
Azure said:
Is it still under warranty? If so, definitely let the dealer fix that hot mess.
Lol, "Hot mess"? How long have you been waiting to use that phrase? :D
---------- Post added at 08:36 PM ---------- Previous post was at 08:32 PM ----------
Oh btw, welcome aboard NM Mustang guy! :D
WoW.....that sucks! It's not so cheap now?
Homemade?
You need a parts car thats been wrecked really bad... if what they said is true.
You're right, needs a part car, will you elaborate on "Homemade intake"??
Find another dealer
If it has under 36,000 miles on it the Warranty should still cover the repair even if lightning did hit the car.
It is imposable for it to have been hit by lightning anyway. It would have had to be grounded to do any damage and if it was grounded it would probably have caught fire.
Before I spent $10,000 on the computer stuff I would think of getting a nice old fashoned crate engine from Ford and forget about the computers.
Discussion Starter #11
The car has full power, I can hear the fuel pump turn on. All the electronics on the inside of the car seem to work like the gauges radio etc. but to cranking of anykind. I thought it was going to be a theft system problem. If every single module in the car was blown would you get the gauges or signals to work? I'm having it towed to my house tomorrow I'm going to jump the starter and see what happens.
So no one knows what happened to it? This is really strange.
Maybe the car has been sabotaged? Previous owner couldn't afford it so he caused something to happen to the car do that his insurance would payout and he could walk away from it.
That's a whole lotta zeros. Now totally out of the question but which part of NM are you in?
I wonder if you can find a place that does repairs on the different modules,,I know the FICM,on the ford diesels,,6.0,,they go out alot,,its the injector module,,and we have them repaired,,
It probably just needs to be reprogrammed.
If the radio & lights etc are all working then the problem is probably the chip in the key is not programmed to the computer. The dealer should not have blown you off. Call the Ford hotline and raise hell. (That is if your car is under 36,000 miles) Even so the dealer should try to help you and not just replace everything in the car. That is just """WRONG""" :mad:
Ain't nothing but a bunch of "PARTS CHANGERS" at these dealerships anymore. No Mechanics left working at all.:banghead:
I agree,,you need to have someone that has some experience and a good scanner ,,to come up with a better conclusion,,Im only up to 08 on electronics at work,,so im not sure how much has changed since then to 2012,,but alot of the modules are interchangable,,except the pats system,,which is intergrated in the pcm i think.The reason i say that the scanner we have you use the same personally key to access the security and the pcm.The pcm if you used another one that will have to be reprogrammed..I pretty sure the pcm and the catylitic convertors are both warranty for 80000 miles,,theres a few items that are covered further then the 36000 miles,,they just dont broadcast it,,do some research
PATS Module is around the ignition module itself. Still is on the newer too. (I do a ton of remote starts...plus I service a/v and security for two ford dealerships...) If everything in the car is coming on, fuel pump, dash lights, etc. Does the motor turn over? Doesn't seem like it from your posts. Anyway, if it is not turning over, it could be the relay underhood, or the starter itself. Even if the PATS or pcm were bad, it would still turn over. Just no fuel or spark. I would start at the ignition harness and make sure there's the proper power in the proper wires. The starter wire tests with a multimeter, should pulse 12volts when key turns. Here's the wiring diagram for your car, hope it helps:
Item Wire Color Polarity Wire Location
12 Volts red (80A) + SJB, black 1 pin plug (G), pin 1
The SJB (Smart Junction Box) is in the passenger kick.
Second 12 Volts blue/red (20A) + ignition switch, black 7 pin plug, pin 4
Starter blue/white + ignition switch, black 7 pin plug, pin 7
Second Starter N/A
Ignition gray/purple + ignition switch, black 7 pin plug, pin 1
Second Ignition N/A
Third Ignition N/A
Accessory purple/green + ignition switch, black 7 pin plug, pin 6
Second Accessory N/A
Third Accessory N/A
Keysense blue/gray + ignition switch, black 7 pin plug, pin 5
Data Bus purple/gray (TX), yellow/orange (RX) data PATS
Transceiver, black 4 pin plug, pins 3 and 4
The PATS (Passive Anti-Theft System) Transceiver is around the ignition switch. The PATS ignition is blue/brown in pin 1, and ground is black/purple in pin 2.
Can Bus High gray/orange (MS CAN); white/blue (HS CAN) data data link connector, black 16 pin plug, pins 3 and 6
Can Bus Low purple/orange (MS CAN); white (HS CAN) data data link connector, black 16 pin plug, pins 11 and 14
Can Bus Sw N/A
Power Lock blue/green - driver kick or SJB, gray 26 pin plug (C), pin 17
Power Unlock yellow/purple - driver kick or SJB, gray 26 pin plug (C), pin 4
Lock Motor gray/brown 5 wire driver kick or SJB, black 32 pin plug (D), pin 6
Driver Unlock Motor blue/green 5 wire driver kick or SJB, black 32 pin plug (D), pin 28
Parking Lights (-) gray - headlight switch or SJB, black 52 pin plug (B), pin 31
Parking Lights (+) purple/white + SJB, gray 13 pin plug (E), pin 6
Hazards brown/yellow - hazard switch or SJB, black 52 pin plug (B), pin 48
Turn Signal (Left) blue/green (F) + SJB, black 26 pin plug (F), pin 21
The rear turn signals are gray/brown, brown/purple, and white/green at the BCM B, black 24 pin plug, pins 4, 3, and 2. The BCM B (Body Control Module B) is in the right side of the cargo compartment.
Turn Signal (Right) yellow/purple (F) + SJB, black 26 pin plug (F), pin 23
The rear turn signals are purple/orange, brown, and gray/purple at the BCM B, black 24 pin plug, pins 16, 15, and 14. The BCM B (Body Control Module B) is in the right side of the cargo compartment.
Headlight blue/white - headlight switch or SJB, black 52 pin plug (B), pin 30
The SJB (Smart Junction Box) is in the passenger kick. May need to interrupt the headlight switch ground when triggering this wire. It is black/purple at the headlight switch, gray 10 pin plug, pin 3.
AutoLights purple/green (interrupt to turn off autolights) - headlight sw or SJB, black 52 pin plug (B), pin 50
Reverse Light green/brown + BCM B, black 24 pin plug, pin 5
The BCM B (Body Control Module B) is in the right side of the cargo compartment. On vehicles with auto-dimming rearview mirror, can also use gray/brown (+) in the passenger kick, harness to rear.
Left Front Door Trigger green/purple - N.C. driver kick or SJB, gray 26 pin plug (C), pin 14
Right Front Door Trigger white - N.C. passenger kick or SJB, gray 26 pin plug (C), pin 2
Left Rear Door Trigger N/A
Right Rear Door Trigger N/A
Dome Supervision gray/purple + SJB, gray 14 pin plug (A), pin 9
Trunk/Hatch Pin gray/orange - N.C. SJB, gray 26 pin plug (C), pin 16
Rear Glass Pin N/A
Hood Pin blue/orange - N.C. hood switch or SJB, black 26 pin plug (F), pin 10
Trunk/Hatch Release brn/yel (coupe), brn/yel or brn/pur (convertible) - release switch or SJB, gray 26 pin plug (C), pin 20
Trunk Release Motor brown/blue + SJB, black 32 pin plug (D), pin 31
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm yellow/gray (driver door key lock) - driver kick or SJB, gray 26 pin plug (C), pin 9
Factory Alarm Disarm green/purple (driver door key unlock) - driver kick or SJB, gray 26 pin plug (C), pin 8
Disarm No Unlock see factory alarm disarm
Trunk Alarm Shunt N/A
Tachometer gn/bu, gy/ye, pu/gy, ye/og, bn, gn/wh, gy/bn, pu/o ac any fuel injector, black (V6) or gray (V8) 2 pin plug, pin 1
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal black/yellow (input), blue/orange (output) - N.O. clutch switch, black 2 pin plug, pins 2 and 1
Fuel Pump purple/green (x2 on 5.4L) + driver kick, gray 8 pin plug, pins 6 and 7
Rear Defroster white/orange - latched HVAC Module, gray 26 pin plug, pin 2
Mirror Defroster N/A
Left Front Heated Seat white/blue - latched HVAC Module, gray 26 pin plug, pin 9
Right Front Heated Seat gray/yellow - latched HVAC Module, gray 26 pin plug, pin 10
Speed Sense brown/green ac PCM, black 50 pin plug, pin 25 (3.7L), 14 (5.0L), or 36 (5.4L)
The PCM (Powertrain Control Module) is in the engine compartment, next to the underhood fuse box.
Brake Wire purple/white + brake switch or SJB, black 52 pin plug (B), pin 40
Parking Brake white/purple - parking brake switch or SJB, gray 26 pin plug (C), pin 1
Horn Trigger blue/white - horn switch or SJB, black 52 pin plug (B), pin 41
Wipers blue/orange (L), purple/orange (H), blk/pur (grnd) - wiper switch, black 16 pin plug, pins 16, 9, and 15
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
WoW --That is why I love this Forum.
WTFDiesel,
This is the best advise on this post. I'm sure you just saved MN Mustang guy a lot of $$$$ and that does not include the grief.
I'm going to copy this information and stick it in my Mustang Folder. I also have a 2012 and it may come in handy for me or someone else someday.
This has to be the best Mustang Forum "EVER" The Members like you with all of your knowledge and sharing it to help other members is really great. I'm pretty certain that NM Mustang guy thanks you and I know I certainly do.
:good:Ronnie
1 - 20 of 32 Posts
