1 - 12 of 12 Posts
Discussion Starter #1
Is it just me, or do you see your hood lift and move when at a speed of 70+? I'm wondering if it's a high pressure zone under the hood? My concern is it must be putting a great deal on stress on the latch. Thx.
What year is your car and how much does it lift??... My '04 GT hood used to lift a little until I removed the rubber seal at the back of the hood towards the windshield!....
Discussion Starter #3
E, it's an 06 GT. I removed that weatherstripping last weekend, and it did seem to help. before that, I was seeing an inch or so lift. Now it's less, but it still does rise.
Thanks, Steve
If you are seeing an inch or so before, then you might want to check and see if your hood is bolted down tight!.. That is alot of movement!.. When I removed my weather-strip my hood stoped moving all together!..
I've had 2 05 GTs and an 07 427R and they each have a lot of hood movement..
Hood pins are a very common upgrade for the newer Mustangs....
Never knew the '05 and newer to have that problem!... Hood Pins are a near future upgrade for me too!.. Mostly for the looks though!.. Lol
It's not me, it's you.
Yeah, my fiber glass hood gets real shaky at 100+ I've got a set of flush mount hood pins but I'm tryin to grow the ball balls to cut into my hood! Lol, once you start cutting, there's no turning back!
It lifts on our 08 GT around 75-80
I had a heat extractor hood on my first GT, bought a set of pins and was scared to instal them too! F'n up was scarier then the hood flapping around some! Never did install them! Never even bothered to buy them for cowl on my 87' lol
1 - 12 of 12 Posts
