Im in philly for work until next week, before i left i stored the stang for the winter but couldnt open this damn thing to put fuel stabilizer in! I figured it was just a latched opening. Never looked how a fuel nozzle can open this. Any tips?
Not quite...you should be able to use any funnel that is long and skinny enough to fit in the gas filler tube far enough to push the metal tab and seal open.
Thanks everyone I knew that little funnel was for something! I did use the two funnels in my garage which did not open it, then when you guys mentioned that part in the trunk i remembered I had seen it before. Thanks! Fuel stabilizer is in and stang is all stored and safeNot quite...
If you look closely, what you have are two small tabs on opposite sides of the filler neck, above the spring-loaded flap. If those two tabs are not pushed outward by a reasonably round, proper diameter fuel filler, or similarly sized funnel, then the spring-loaded flap is locked shut as a vapor stop.
So, you can use a funnel roughly the same diameter and roundness as a gas pump fuel filler, like the funnel Ford gives you in the trunk, or get a similar sized funnel somewhere else. But you can't (easily) use just any old funnel.
If you are desperate, it is possible to use some 'tools' to depress both tabs, then push on the flap, and wedge it open with something like a long thin rod to keep it from coming all the way back up and locking. Then, you could insert a smallish funnel. Again, this is last ditch, stuck in the middle of nowhere stuff.
Good Luck!
FluxPrism
