1 - 14 of 14 Posts
I use Grease Lightning on everything in the egine bay except anything that is Polished aluminum. I use a mix of 50% GL and 50% water in a spray bottle Leave it on for maybe 5-10 min then rinse off. It comes in a gallon container and is 1/5 the price of Simple Green. You will not need to wipe much off Grease lightning lifts most grime unless it is caked on.
You want to **** me?
you gotta cover anything up when youre spraying the engine? Or is there anything really that cant get wet?
at work we use a "special" cleaner, haha and a power washer... only on chevys and hondas we worrie about getting things wet, a mustang is ok to wash just to go puttin 100 gal of water on there and make sure your engine is cool,
keep the area in red dry for the most part. if its under the hood it can get wet to a point.. ZIM, yeah aftermarket wires should be kept dry, same with your power wires for AMPS and what not..
i clean it all by hand its not hard really it doesnt get in the cracks and all that good but i dont like putting water on the motor or what not......
1 - 14 of 14 Posts
