If all you are doing is putting on is the power brake booster with no other changes. all you need is the Brake Power Booster/w master cylinder assembly. [email protected]
Ford used the same wheel cylinders for both power and non power brakes.
You will need to modify the brake line running to the master cylinder, and install the vacuum line and fitting in to the intake manifold. no more than $50 for these parts.
PS ignore that 15 pounds of vacuum comment above. Your engine will do just fine. Nothing on earth can pull 15 psig of vacuum.
