1 - 10 of 10 Posts
Discussion Starter #1
So far I have a CAI long tube headers, Pypes offroad x-pipe and pypes midmuffler exhaust and a diablo t-1000 tuner..just curious..I have an 05 gt
We could throw numbers around all day but the only real way to find out would be to dyno it. I would say with those mods you probably got around 30-40 HP/TQ
OneSick07 said:
Maybe 330 I'd say more aroun 320-325 at the wheels tho.
Haha hell no, probably 280-290 at the wheels
Intake and tune will grab you probably 15hp, longtubes should free up anything between 15 and 20 depending on the flow of the brand, i wouldn't expect anything from removing the cats except anything from 2-5 on the offroad x. If I had to throw out a guess, you're probably sitting on 280-290 at the wheels. Depending on the tune mostly, elevation and octane in the fuel.
Yeah, I'd agree that you are around 280 or so.
Longtubes. Offroad pipes. Cams CAI and tune can put you 300+ at the wheels? Is it possible to get 350 without going FI?
Here is what many many many speed shops have told me:
cai
Cmdp
Tb
Off rd mid
Long tubes
Cams
Port n Polish heads
pullies
Dyno tune
Will only get you around 360wrhp ... I don't quite understand it soooo my goal is to do all the above to see if they are correct...
They claim it's impossible to achieve 400wrhp w/o building a bottom end. I think w proper.supporting moddifications ie; aluminum driveshaft
Aluminum flywheel
Strong clutch
Uca, lca,
Pan hard bar, and brace
rear sway bar and links
Light radiator support
Tubular k member
Soft compound tires
And gears
Not that you need all that but if you did I truly don't see how you can't make 400wrhp n/a but even if you still don't have 400 w all that hp no longer matters that's high 11s... I would think
I have a little over 350 at the wheels with cams, headers, cai, x pipe and bassani axle backs and an aggressive dyno tune
1 - 10 of 10 Posts
