1 - 7 of 7 Posts
Discussion Starter #1
2001 Ford Mustang. How do I change the blinker? It is the blinker on the back of the car. (left side). I pulled a part some of the lining and there is some red button, and a few screws. Or if you know where i can take it to get it replaced for cheap.... I live in Oklahoma City.
there are 3 11mm nuts holding the tail light assembly in place. remove the nuts and the assembly slides out. then just replace the bulb. takes about 10 minutes.
you should be able to access the rear brake light housing from the trunk.
where the wires go into the housing, you should be able to turn and remove the light bulb socket, and replace the bulb.
go check your nearest auto zone checker or napa they can show you wat you need and help you replace it they'll charge for the bulb but not for the help to put it in and bulbs arent that expensive well then again i haven't boughten them in a while
1 - 7 of 7 Posts
