1 - 10 of 10 Posts
Discussion Starter #1
I have a 1999 mustang GT what would be a good engine swap for more power? or should i just mod mine?
You can swap in a DOHC 4.6L or a 5.4L if you get a new hood. But it would more practical and easier to go with a supercharger or turbo. I have Kenne Bell supercharger on my 03 GT and I an very pleased with it.
Graham H : It's more than top speed. Unless you live in Germany, top speed is largely irrelevant. Even those sub- 2-liter superminis that are popular over in Europe can exceed the posted speed limits. For the most part Americans like acceleration. In the UK a 0-60 time of 11 seconds is considered acceptable, over here it is not. Since we are not burdened with ridiculous fuel taxes, the average person here can buy and afford to run a petrol V8 powered car.
If it's still strong and reasonably low mileage, go with a set of 3 valve heads, open exhaust, bigger injectors and cold air intake. Total cost - 3-5 grand depending on how much work you do yourself.
If you want to swap in a new motor - consider a crate 5.0, or look for a 32 valve 4.6 from a Cobra. Unlimited horsepower potential with the SVT engine.
Just go for headers and extractors if the engine is in good condition.As far as power is concerned the GT engine is very good!!! for the sizeof the car it has to pull along!! Pwer to weight ratio is the best!!
charlie, it is a 4.6L not a 5.0L in 1999. Stay with that motor and mod it. There are soo many things to do to make more power. Start with exhaust, and then move to the intake side.
There's plenty of mods available for modular engines. This month's issue of MMFF (Muscle Mustangs and Fast Fords) is featuring mod-motor upgrades.
If the car has under 100,000 miles, just supercharge or turbo it. If not, swap out a cobra engine I've seen a few they're like 6 grand
Just modify the engine you got. You can give it more power without swapping. Save money and time.
just re-build yours bore it out 30over or 40 over or 60 over, but beware its going to run hot, the thinner the sleeve the hotter the temp. if you want hp. thats what ya gotta do. or just stay with 5.0 and put bigger cam. but you need to raise commpression on pistons . theres alot to do ford mustang engine is a power house, its like a hp factory, good motor, just depends on how much money you want to spend.
I'm just curious but you Americans live in a country that won't let your cars be driven at half the speed they are capable of so what is the point of increasing the power you already can't use?
Is it a testosterone thing or what?
GO for the Audi naturally aspirated V8, you can pick them up for about $6500, but they are difficult to find.
Good times!
1 - 10 of 10 Posts
