1 - 7 of 7 Posts
Discussion Starter · #1 ·
i noticed it yesterday while i was driving and i was picking it up to 40mph and it wudnt switch gears and the rpms were about 3500 rpm
can anybody give me an idea of what could be the problem?
i also noticed that the carburator was leaking gasoline from where its connected to the manifold
fuel leak is important to fix wil not be connected to gearbox issue,
check fluid level in gearbox . if ok? check all vacum and linkages to gearbox/ engine.
failing that intrenal valve for brake band. actuator effecting gear change will have failed. you may be able to get an easy fix but often an exchange tranny is best. use an auto box specailst or trusted garage only.
you might check your tranny fluid and make sure there is no red fluid underneath where u park ur car and if u didn't know already an automatic transmission runs off of pressure so if u dont have enough pressure it may not work at all, to check ur tranny fluid park the car in neutral and pull the tranny fluid fill dipstick and check the fluid.
1 - 7 of 7 Posts
