1 - 10 of 10 Posts
Discussion Starter #1
I have a 95 3.8 . When I start it it revs up to. 3000 rpm . I put it in gear it drops to 1500 and stays there. I've checked for vacuum leaks,changed the throttle positioning sensor,changed mass airflow, o2 sensors , even a new ecu. I'm lost can anyone help?
Have you checked the dpfe. If you have a haynes manual, it will tell you the voltage specs. Get the autozone one if you do need one. I found out, after spending $100 for a "genuine" motorcraft dpfe, that they get that same piece, scrape off the logo, and sell it for a third of the price!
(edited above some)
Diffetential pressure.... Lol. I forget the exact name, but it's vacuum lined in with the egr. It makes sure the egr is functioning properly.
You'd need a multi-meter to check it.
---------- Post added at 07:11 PM ---------- Previous post was at 07:09 PM ----------
DHall31 said:
I Tried that also it still is revving think resetting the ecu would work?
Any time you disconnect the battery for a few min, hours, days.... It should reset the ecu. Couldn't hurt. Just make sure you have your radio code.
Discussion Starter #7
Mustang Convert said:
(edited above some)
Thank I'll give it a try tomorrow
DHall31 said:
Well that didn't work I'm all out of ideas
You said you got a new ecu!.. Is it possible that the program in it is wrong??.... ie. idle is set real high for some reason?!?.... Don't know just trying to brainstorm a little for ya!!.....
Discussion Starter #10
I've tried everything everyone has told me to no avail this car is really ticking me off lol I can't figure this thing out . I'm not a mechanic and mechanics are scratching their heads on this one. Any more advise will be greatly appreciated.
1 - 10 of 10 Posts
