1 - 2 of 2 Posts
Discussion Starter #1
I replaced the coils 1000 miles ago and last night the crank position sensor went out. I was ford to drive it home and I replaced it today then replaced all the plugs cause some were fouled. For some reason cylinder #8 will not fire. Any suggestions?
How do u mean fouled? Was cylinder 8 fouled? Cyl#8 stopped firing after u replaced the plugs? Did you make sure that coil is securely mounted to the plug and the connector is secure?
1 - 2 of 2 Posts
