I would advise to get some premium 4gauge power wire (not from walmart) and at least a 100-125ANL fuse to run inline from the battery to the amp. The closer the fuse is to the battery the better, no further than 18" from the battery though.Yes I got the box with 2 12 inch and a 1500watt amp.. I just need the installation kit
That works too, I grew up doing audio so it's easy lol.I'd advise you take it somewhere so you don't fry your car lol just one of those areas that needs to be done right just my 2 cents shouldn't cost much
+1 not but a few wiresThat works too, I grew up doing audio so it's easy lol.
That's right, still a little bit more to it but all in all it's pretty simple. soon here I'm going to take my gt I just got and do my big 3 and then run all my stuff for the system. I might do a write up to help anyone who's looking to do it.+1 not but a few wires
Big 3 referring to a wire upgrade in the engine compartment. (Block to ground, chassis to ground, positive to alternator) the bigger the wire the less resistance therefor giving you a .2-.8 more volts on the battery while running. YouTube it and google it you'll see. Is it necessary for you and me? Probably not, but when I have all the stuff to do it from my previous car then so be it.Big 3? And I am as well thinking about putting my old system in my new 04 gt .. 2 12 alpine type -r with a JL amp but my box is way too big .. Should I downgrade or customize a box ? .. And I don't want everything on my car to rattle anyway to Provent that .. I know dynamat is good but .. Idk and how do I get my faceplate and shift plate to come out without breaking it ugh
Just take out the spare and remove the carpeting and work it in there through the trunk. That's what I did and I had 2 12"'s in a ported box as well but now I have one 12" jl w7 and it hit louder than my 2 12's I had. LolMy box is ported in middle and they wouldn't fit through the trunk maybe backseat but I highly doubt it and yeah that's my problem air space good enough for the subs alpine type R and for dynamat ya I just don't want the Interior to fall apart
Yeah it's easy to install but with the box we had I'm guessing his was bigger for the 15 it's a little difficult putting it inside the trunk lolI think its an easy job, i put a whole new system in my car head unit door speakers rear speakers and two 10 inch subs with a 1200 watt amp with no problems. Sounds great
