Thanks for the help, how do you suppose I hide the wires?Rm360 said:If you have light strips you can pull power from the fuse block without going thru the firewall, the cigarette lighter and radio always have constant power. There are two ways to do this pull the fuse , stick your wire into the slot, push fuse back in, or autozone sells a fuse with a wire already on it with a butt connector and you can wire it that way, the grounds can be put where it will make good metal to metal contact, wire them to your switch and you should have some nice lighting
I hid my sub and amp wires under all the plastic like panels in my car. Almost everything in the interior that is plastic just snaps in. I would say pull it up put the wires under or in and run it through to where you need to go.Thanks for the help, how do you suppose I hide the wires?
How do you suppose I pull out the center? With the music audio and heat and stuff? I wonder if there was a clip on it on youtubeV6in said:I hid my sub and amp wires under all the plastic like panels in my car. Almost everything in the interior that is plastic just snaps in. I would say pull it up put the wires under or in and run it through to where you need to go.
How'd u get the LEDs behind the vents?This is my setup
Oh nice! I needa figure out how to do that with my 12I hot glued one for each hole , on my car I just pop the dash face plate off to do it
I put it right behind my obdIIya i wanna do that to on my 12 but dont know where i want my switch
Nice.I like the red behind the vents.This is my setup
Sick love the blue with the orangeThis is my setup. I have 2 orange lights on my speakers that are on my rear window. Then i change the ones under my dash and my center console to all sorts of colors
