1 - 17 of 17 Posts
Discussion Starter #1
I just bought a 2000 gt and the car feels laggy and it rocks back and forth when trying to push gas. My engine light also came on and it started blinking. I also hear like a nouse coming from where I shift if anyone can help I would appreciate it so so much
Get the code for the cel and see what pops up. Usually when it blinks you should stop driving it
Check youre coil pack and spark plug on whichever one is misfiring. Either bad plug or corroded coil
Discussion Starter #13
Oh I forgot to mention that the alternator was changed and it also has the battery light could that be causing the problem? I saw someone mention this so im jw here
Make sure you're battery positive and negative are tighten firmly. I had the same problem with the battery flashing and turned out it wasn't making contact
Discussion Starter #15
Okay but I mean could that be why it jerks im going to get the codes checkef just in case but I just dont know what's going on lol
Discussion Starter #17
Well I took it to autozone and they said cylinder 4 was misfiring so I replaced the spark plugs and seems a lot better:)
1 - 17 of 17 Posts
