1 - 16 of 16 Posts
Discussion Starter #4
Alright guys so here's my next surprise my stang has revealed. I know 88 didn't have MAF mine does so here is what the computer was out of (see pic) the car does slightly searches for idle but still feels ridiculously fast.. So i don't think its really affecting its performance .Is there something going on with this ECM that I might have to do to get it to smooth out or is that normal with the MAF swap.
Wats up man.... I no im kinda jumping to ur thread.butt as I was reading i realized that my 88 also has a maf... Why would u even do the swap??? Dose it improve anything?
Discussion Starter #6
As far as I know this year doesn't have MAF. I think it allows the air/fuel/spark to better adjust Don't quote me on that. But that's my understanding lol. If yours has it already I'm guessing you have a newer year ECM in yours also. Any idle issues?
Your tps may be out of adjustment or you may just need to set your idle. Where abouts is it idling.
Banned
You will need to get some driving time in to let the ECU/ECM "learn" its operating parameters. Usually 20-30 miles is sufficient.
Banned
All 88 Mustangs manufactured for use in California were MAF instead of speed density.
MAF is much more forgiving when modifying the engine.
Speed Density is really sensitive to camshaft changes.
Discussion Starter #10
@93 it's at 800ish it just searches 1200-800 randomly.. Thanks for the info Trojan my ECM as in the pic says 92 gt maf so it's def not Cali car Lol. But tires tomorrow so I'll put the miles on it to see if it clears up. It developed a pretty hefty valve tick on drivers side are the stock vslves adjustable? Or is there another surprise awaiting hopefully not bad...
---------- Post added at 05:13 PM ---------- Previous post was at 05:00 PM ----------
How do you adjust Tps?
Discussion Starter #14
Hey guys little update all vacuum lines replaced still searched for idle. Replaced IAC same result lower idle, replaced and set TPS, sweet spot :) idling perfect. Doing springs, wheel bearings, inspection, and done till the hood gets here next week. Stoked!
1 - 16 of 16 Posts
