1 - 20 of 39 Posts
Discussion Starter · #1 ·
Yes I know where to put the jack . Lol simple qustion can I jack up 3 tires at once? Like I want to use jack stands for front 2 ( only have 2) then the jack that came with car for a rear side. I'm plasti dipping rims . Is that bad for suspension or will it be fine ? Thanks sorry if this is dumb but first time really working on own car and its new to me
Just make sure the front is secure on the jack stands.
To answer your question, yes you can.
Don't do that. Just do it in stages. And don't use the spare tire jack. Your just asking for trouble. Use a real 2 ton jack.
Just do 2 rims at a time or buy 2 more jack stands and do them all at once.
you shouldnt leave your car supported by just a jack in the rear, I would pick up two more jack stands (they are cheap)
Very unsafe, especially with the stock jack . You can get by doing that with a floor jack, but do not get under the car what so ever. Jack the back in the center lifting both tires.
cheaper than reconstructive surgery if a car falls on your face or a funeral :( regardless of what you do just keep it safe
Just in case, please have someone there to take pictures of the car on you......Oh something else..... then call 911.
Discussion Starter · #15 ·
Well I have a picture of where to place the jack . It's on frame right behind front tire jus Guna jack it up and put one side on stand then repeat . Just never worked on own car before and want to be careful . Rather not bend anything
I really wouldn't do that, at all. Using the spare tire jack for this purpose. You are just asking to damage your car or yourself.
I would wait until you save up and buy a floor jack. You just got your car and you're just asking to damage it just to plasti dip your rims.
Discussion Starter · #17 ·
1. I meant floor jack to jack up frame and use jack stands
2 why would they include the car jack if it would damage the car. I see no problem using the pinch point where the jack is supposed to go and jacking it up and placing a jack stand there . They included it to change tires so it must work .
because using that jack is intended to get one corner of the car off the ground far enough to remove the wheel and put a spare on, not to jack the car fram up high enough to get jack stands under the car.
another member on here already tried that, poor guy, and the thing collapsed on him. Maybe you can ask him if it was made to do that. Thankfully he nor the car was injured.
Discussion Starter · #19 ·
Um I'm not raising my car 5 feet off ground jack up enough to slid jack in after tires off and done lol not arguing jus did it on my 05 when I had no floor jack and it lived. So u mean ya if I was jacking it high I'm sure jack would give way lol
So floor jack on the frame behind front tire is fine then put jack stand? And thanks guys don't wana hurt my baby lol or me but mostly her lol
Why pay for jack stands? Buy some 2x12s and make your own ramps or stands. Use a floor jack to lift the front end and place them
Under then do the same to the rear. 30 bucks or less with wood and nails and you can do better then a jack stand
1 - 20 of 39 Posts
