Easy .. Twist and replaceHas anyone ever swapped out their tail light bulbs for led ones? I plan on tinting my tails and wanted to know if I can just straight swap them out or if I would need anything else since their my turn signal flasher lights as well..
I've always thought you had to use resistors between flasher and light bulb..Easy .. Twist and replace
Yeah I've heard you might need something else as well. But I wanted to see if anyone has done this to their tail light bulbs yetI've always thought you had to use resistors between flasher and light bulb..
They're just led light bulbs but since LEDs are not loads to the flasher, flasher it's gonna think you have a burn light bulbSo they would be just led bulbs or is it like a kit
Good point got there man!I put them in my fox body for awhile, I don't think you're going to get the look you want with them. The housings need reflected light for them to work and the LED's focus all of their light straight out the back. Your lights end up looking like 3 little circle lights instead of the big taillight sections. I almost got rear-ended a few times also when the sun was beating down on my taillights and no one could see the lights even come on.
