1 - 20 of 21 Posts
Discussion Starter · #1 ·
So my 02 mustang isnt really my daily driver, i use my 98 for that. But im building my 02 up for speed and power. Should i go 3:73 or 4:10 gears. I heard you lose MPG on 4:10's but my question is how much city vs highway?
Thanks for any info.:popcorn:
It's more than 120 but lets be honest how often
---------- Post added at 11:40 PM ---------- Previous post was at 11:40 PM ----------
Are you going 120 and I have them on my auto and my accel is 3x better
---------- Post added at 11:42 PM ---------- Previous post was at 11:40 PM ----------
but yes it does lower too speed
Discussion Starter · #5 ·
Very true, just wanted to make sure it could go over. I might not go 120 very often but for that 1 moment when i do, i dont want it to sit at 120 like "What do you want me to do now boss" lol
a few things to think about
1. if you're planning power and speed then why concern yourself with mileage...it only holds you back
2. why do you need to go over 120? you'll never need those speeds even on tracks you're most likely to visit unless it's a road course with a long straight...
3. you won't come close to ever maxing your gears
besides that what are you wanting out of the car in the long run?
^I redlined 4th gear once, factory redline at least haha
If its not you're daily go big, 4.10's will be very fun in an auto car
hey david you thinking about going stouter now that you've got a new DD?
Maybe when I do the 8.8 swap, otherwise FukIt
My understanding of why the 3.73 is better is because of once you're in 5th gear... Essentially the higher the gearing the faster the accel... but once youre in 5th the low gearing becomes better. If you google manual mustang 3.73 vs. 4.10 they probably have a better explanation... But when I was researching for my auto I think that's what I came across
Discussion Starter · #17 ·
Alright Thank you!!
Automatic 4th gear .70
Manual 5th gear .6X (.69 or .68 I forget)
Overdrive gear is not the reasoning behind 3.73's for manual, you have 4 gears to go through with a manual before overdrive, you'll be shifting very quickly with 4.10's compared to 3.73's which can screw you up if you're not the greatest shifter. With an automatic the gears are longer with only having 3 before overdrive, less shifting not to mention the car shifts itself..
Without the gas mileage into perspective, that's why 3.73's for manual and 4.10's for auto.
1 - 20 of 21 Posts
