I am experiencing the same problem with my 04 GT at 67K miles. I replaced my spark plugs with NGK Indrium and I think those are giving me problems. I also am experiencing shaking at higher speeds (may be my tires though)
eouellette18,How do you clean the iac. And the car just doesnt feel as powerful as it did. I'll push on the accelerator and it feels sluggish. I used to run the 93 race tune from bama, but I switched it to stock settings after replacing my throttle body. Would a clogged fuel filter or fuel injectors cause this too?
I doubt the filter is your problem, considering the issue accorded before and after the filter replacement. Make sure you check every coupler in the intake. Make sure the fitment is perfect and you tighten all the clamps. As I said before, this is an easy issue to have if there's an air leak in your CAI.I haven't tried adjusting/ tightening it yet. I also replaced the cai filter with an autozone filter as it was cheap and quick replacement. Could that be not sealing right or something?
