1 - 5 of 5 Posts
Discussion Starter · #1 ·
Hey all,
I just purchased a 2004 Mustang GT convert about 80k miles on it, manual transmission.
I have noticed when I shift from first to second gear, I hear a bit of a "thunking" noise. I don't notice this when going from neutral to first or to second, third, fourth or fifth. It is not very loud but it's there. I did not notice it at all when test driving it, so I may just be paranoid.
I haven't driven a standard in a long time, and I have never driven a standard transmission Ford nor a car with any power in general, so I am not entirely sure what is normal and what is me just driving poorly. :D
After searching and Googling, some say this is normal, some say it could be the U-joints, motor mounts etc. Any opinions?
Banned
Sounds like a transmission mount to me. Could be worn enough to if you make the car buck a little when shifting it knocks around some. Il bet once you get used to driving a manual you wont hear it anymore but you should still try to locate the problem and replace it. Generally if it was a u-joint you would feel a vibration at a certain speed, mostly at higher speeds. Does the shifter handle vibrate at all?
Discussion Starter · #4 ·
Were is the sound coming from?
Hard to say, kind of under the car.
Yea it does vibrate when I hold it, but I did not notice that at high speed in particular, I can "feel" the engine through the shifter. It is a high-frequency vibration coming straight up the shifter.
Discussion Starter · #5 ·
The vibration, I am quite positive, is just the normal amount for a standard transmission.
Anyone have tips on how to examine the motor/ tranny mounts or the u joint?
1 - 5 of 5 Posts
