1 - 13 of 13 Posts
Discussion Starter · #1 ·
I want to spend less than $500 total. I have tune, CAI, TB spacer, and axleback SLP.
I dont want gears so what could I do to add power for under $500?
It won't be much, but pullies is probably the only thing.
Don't want gears because with install they are super expensive and same with headers.
Brenspeed has 4.10 gears for $160 and installation should only be between $300-$400. So you're right around $500.
Ya that could work. I just want more options and I guess I don't have too many
Depending on the gears you have now, that's about the best $500 you can spend for noticeable change. All other mods are realized until you hit the power band and upper rpm's.
Discussion Starter · #11 ·
I got stock 3.55's manual transmission. I was thinking 3.90 was the highest I wanted to go with gears cus it's a daily driver
3.73 would be an improvement, but not as dramatic as 4.10. If you're going 3.90, I'm not sure that it would make much difference to go to 4.10.
1 - 13 of 13 Posts
