1 - 3 of 3 Posts
Discussion Starter #1 (Edited)
TheDiablosport T-1000 tuner comes from AM with three installed tunes. I’ve read that with this tuner one can modify the loaded tunes. My question is: Can the Bama tunes loaded on the T-1000 be modified by the user without the need to request a new tune, if, for example, you want to change the gear ratio in your 91R tune?
-wfpostle-
Not familiar with the t-1000 but the old diablo would allow for you to adjust parameters in the tune such as tire, gear ratio, Rev Limiter and even some deeper things like spark and timing. I would think you could. Call Bama and they should be able to tell you and walk you through the screens.
The older SCT X3 has an option to customize the tune and allows you to edit it as well.
AmericanMuscle.com
wfpostle,
You can make some simple adjustments from your tuner if you'd like. However we don't usually recommend you making any adjustments yourself. We offer the free tunes for life program and encourage our customers to take advantage of it!
Give my Bama team a call and we'll hook you up with a revision in just a few minutes! Our Bama Performance tuning specialists are here in the building Monday-Friday from 9AM-5:30PM EST and Saturday 9AM-5:30PM EST. You can hit them up directly at 888.226.9764.
-Dan
1 - 3 of 3 Posts
