21 - 25 of 25 Posts
Using a transfer pump which costs about $10 is easier than having to disassemble the center console. That shifter boot is a pain to put back on. With the pump you can fill it from under the car.
Great guide though. I was curious to see how people filled it through the shifter.
In 100% agreement. Changed mine twice with the Amsoil pump.
Using a transfer pump which costs about $10 is easier than having to disassemble the center console. That shifter is a pain to put back on. With the pump you can fill it from under the car.
That gear oil stinks if you end up spilling any inside your car interior. I vote for the pump from underneath method.
Just changed mine with Royal Purple
I just changed mine in my 2012 GT 6 spd with Royal Purple and it shifts much smoother I used a pump from Harbor Freight i bought for approx $7.00 and it worked great. It has in and out hoses and a plunger pump. Great pump for the money. I would recommend that you remove the filler plug not just loosen because when draining the fluid in gurgles and splashes making a mess otherwise.
21 - 25 of 25 Posts
