1 - 3 of 3 Posts
Discussion Starter · #1 ·
After I hit the curb, the car is pulling to the right pretty hard.
I went to five different shops for some estimates and they were telling me different things.
Firestone told me that I need to replace two struts 'caz the right passenger side wheel shake/vibrate when jacked the car up. $130 Parts + $180 labor
Pepboys told me that I need to replace a steering knuckle. $120 Parts + $160 labor.
Sears Auto told me I need to replace an inner tie rod just on the passenger side. $40 parts + $120 labor.
An independent alignment shop told me to have the front crossmember bar take off and put it on again. $130 labor.
Ford Dealer had done a "smart" job by telling me to replace inner and outer tie rod, hub assembly, struts, and lower control arm; pull sub frame forward, etc. (Basically they wanted me to replace everything on the passenger side) $600 parts + $1200 labor.
Who should I listen to now? I am totally confused. I know the Ford dealer would probably repair it, but they wanted to charge me $1800+. I am just a poor college student who's having trouble to pay off the tuition already. sigh.....
If I turn my steering wheel all the way to the left side, I can hear the metal crank noisy even thought I hit the curb on the passenger side.
Any suggestions?
Btw, I did have an alignment performed after hitting the curb, but the car is still pulling to the right though not as much as it was b4 the alignment, and then I did have the guy at bear to shift the main crossmember for me. Again, the alignment improved again, but my car still pulls to the right slightly.
P.S. I just realized that my front passenger side tire is displaced towards the rear - at least it looks that way from the fact that it is at least 1 inches closer to the rear (the mud flap) than the left wheel.
If I must have something replaced, which one should I go first? Inner/Outer tie rod? Struts? Control Arm?
My car is a 2003 Mustang V6.
sounds like the inner and outer tie rods could be bent, also even the steering knuckle may be bad. the strut wont cause the car to pull to the left. if your getting all this done u might aswell get an alignment also, since its probably out of alignment
1 - 3 of 3 Posts
