1 - 12 of 12 Posts
Discussion Starter · #1 ·
What can be the cause of my mustang gt problem? While in park it accelerates good but once i dri e it it wont accelerate and it shakes i already checked it top to bottom but cant seam to find the issue of my gt's problem any advise..
You have checked all vacuum lines?
---------- Post added at 02:08 PM ---------- Previous post was at 02:07 PM ----------
Auto?
So in other words when under load it boggs down and misses? What kind of fuel you use? Whats done to the car? What did you check?
Check for a vacuum leak, and double check the timing.
+1, if none are found I would look into replacing the fuel filter, and checking your ignition system. You may just need a tune up if it hasn't been done recently.
+1 cap, rotor, plugs, wires, oil, coolant, air filter, fuel filter, vac lines is a good place to start. ONLY replace these if they are old and need replacing. Dont throw parts at the problem.
I had a similar problem. My first advice check your timing and wire routing.
I had the same problem just recently I replayed my fuel filter and my EGR valve but I couldn't seem to find the problem then I did new spark plugs so then I night new wires and one of my wires on the top cap wasn't on right so that was my problem and now I finally got it after so long it runs good again! You might want to check that!
Discussion Starter · #10 ·
Yes. Ive checked all vac Lines its wierd the problem started right when i replaced the stock fuel pump to a 155.
Discussion Starter · #12 ·
What i did i cleaned the fuel lines ordered some new injectors cuz the ones it had were nasty. Installed some new accel wires sparkplugs, fuel filter and now i just have to wait for the inj. To arrive and install them..
---------- Post added at 11:27 PM ---------- Previous post was at 11:24 PM ----------
Thats what i had tought too but i dropped the fuel tank took the fuel pump out and checked it out and it worked great and the pressure looked good..
1 - 12 of 12 Posts
