1 - 5 of 5 Posts
Discussion Starter #1
Ok so when replacing my radiator and deleting my ac i disconnected my abs module. when I hooked it back up I got in my car, turned the key on, a buzzing came from the rear of the car and it will not start as if the computer is telling it not to start. what could cause this??
Unhook your battery for about 30 mins and c if that resets anything. Also check your fuel pressure at the rail to c if u have the right amount of pressure
Sounds like you tripped the fuel relay. In the trunk behind the left trunk covering (there's a hole actually, no need to remove the trunk lining, there's a fuel pump reset button. Its a red button and is mounted to the framework on the other side of the tail light I think. Hold it down 3-5 seconds. Try again. I've had to reset it a couple times.
1 - 5 of 5 Posts
